[1] Solidigm analysis based on data from World Bank and Gartner Q2 2022.
[2] USENIX. “Operational Characteristics of SSDs in Enterprise Storage Systems: A Large-Scale Field Study.” February 2022. www.usenix.org/system/files/fast22-maneas.pdf.
[3] AI News. “State of AI 2022: Adoption plateaus but leaders increase gap.” December 2022. www.artificialintelligence-news.com/2022/12/07/state-of-ai-2022-adoption-plateaus-leaders-increase-gap/.
[4] IDC. “New IDC Spending Guide Forecasts Edge Computing Investments Will Reach $208 Billion in 2023.” www.idc.com/getdoc.jsp?containerId=prUS50386323.
[5] The Linux Foundation. “State of the Edge Report 2020 - State of the Edge.” https://stateoftheedge.com/reports/state-of-the-edge-2020/.
[6] TechTarget. “QLC vs. TLC SSDs – Which is best for your storage?” June 2022. www.techtarget.com/searchstorage/tip/QLC-vs-TLC-NAND-Which-is-best-for-your-storage-needs.
[7] University of Toronto study of 1.4 million industry SSDs in enterprise storage deployment. Source: USENIX. “A Study of SSD Reliability in Large Scale Enterprise Storage Deployments.” www.usenix.org/conference/fast20/presentation/maneas.
[8] Enterprise Storage Forum. “Survey Spotlights Top 5 Data Storage Pain Points.” August 2018. www.enterprisestorageforum.com/management/survey-spotlights-top-5-data-storage-pain-points/.
[9] Open19. “An Open Standard for the Datacenter.” www.open19.org/technology/.
[10] TechTarget. “Performance, reliability tradeoffs with SLC vs. MLC and more.” September 2021. www.techtarget.com/searchstorage/tip/The-truth-about-SLC-vs-MLC.
[11] Comparing sequential read bandwidth of 6,700 MB/s for Samsung PM9A3 and 7,000 MB/s for Solidigm D5-P5430.
[12] Comparing sequential write bandwidth of 4,000 MB/s for Samsung PM9A3 and 3,000 MB/s for Solidigm D5-P5430.
[13] Comparing latency of 15.36 TB Solidigm D5-P5520 of 4 KB RR (75 µs), 4 KB RW (20 µs), 4 KB SR (10 µs), and 4 KB SW (13 µs) for an average of 29 µs to latency of 15.36 TB Solidigm D5-P5430 of 4 KB RR (109 µs), 4 KB RW (14 µs), 4 KB SR (8 µs), and 4 KB SW (10 µs) for an average of 35 µs.
[14] Industry expectations as defined in https://www.techtarget.com/searchstorage/tip/The-truth-about-SLC-vs-MLC.
[15] Forward Insights. SSD Insights Q1 2022.
[16] Solidigm drives are tested at the neutron source at Los Alamos National Labs to measure Silent Data Corruption susceptibility to 1E–23 and modeled to 1E–25. The testing procedure begins with prefilling the drives with a certain data pattern. Next, the neutron beam is focused on the center of the drive controller while I/O commands are continuously issued and checked for accuracy. If the drive fails and hangs/bricks, the test script powers down the drives and the neutron beam is turned off. The drive is subsequently rebooted, and data integrity is checked to analyze the cause of failure. SDC can be observed during a runtime causing a power down command or after reboot if the neutron beam has hit the control logic, hanging the drive as a result of in-flight data becoming corrupted. Because drives go into a disable logical—brick—state when they cannot guarantee data integrity, brick AFR is used as the measure of error handling effectiveness. Intel/Solidigm drives have used this testing procedure across four generations.
[17] Comparing the KIOXIA CD6-R SSD, available in U.2 960 GB to 15.36 TB, the Micron 7450 Pro SSD, available in U.2 960 GB to 15.36 TB and E1.S 960 GB to 7.68 TB, the Samsung PM9A3 SSD, available in U.2 960 GB to 7.68 TB, and the Solidigm D5-P5430, available or soon to be available in U.2 7.68 TB to 30.72 TB, E1.S 3.84 TB to 15.36 TB, and E3.S in 3.84 TB to 30.72 TB. Solidigm D5-P5430 has higher max capacities for U.2 and E1.S, and it is the only drive in its class supporting the E3.S form factor.
All information provided is subject to change at any time, without notice. Solidigm may make changes to manufacturing life cycle, specifications, and product descriptions at any time, without notice. The information herein is provided "as-is" and Solidigm does not make any representations or warranties whatsoever regarding accuracy of the information, nor on the product features, availability, functionality, or compatibility of the products listed. Please contact system vendor for more information on specific products or systems.
Refer to the spec sheet for formal definitions of product properties and features. Solidigm may make changes to specifications and product descriptions at any time, without notice. Designers must not rely on the absence or characteristics of any features or instructions marked "reserved" or "undefined." Solidigm reserves these for future definition and shall have no responsibility whatsoever for conflicts or incompatibilities arising from future changes to them. The information here is subject to change without notice. Do not finalize a design with this information.
Solidigm technologies may require enabled hardware, software or service activation. No product or component can be absolutely secure. Your costs and results may vary. Performance varies by use, configuration and other factors. Solidigm is committed to respecting human rights and avoiding complicity in human rights abuses. Solidigm products and software are intended only to be used in applications that do not cause or contribute to a violation of an internationally recognized human right. Solidigm does not control or audit third-party data. You should consult other sources to evaluate accuracy.
“Solidigm” is a trademark of SK hynix NAND Product Solutions Corp (d/b/a Solidigm). “Intel” is a registered trademark of Intel Corporation. Other names and brands may be claimed as the property of others.
© Solidigm 2023. All rights reserved.
